View all of the ACE ARP entries associated with an ACL.
- In the navigation tree, expand .
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select Arp.
- Select the parameter and modify as you need.
- Select Apply.
ARP Field Descriptions
Use the data in the following table to use the ARP tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Type |
Specifies the ACE ARP operation. The only option is operation. |
Oper |
Specifies the operator for the ACE ARP operation. The only option is eq (equal). |
Value |
Specifies the ARP packet type. Valid options are arpRequest and arpResponse. |
